I have a 97 GSX that won't start with the ignition switch on the handle bars. The battery is fully charged and if I jumper the solenoid it will start. I can then shut the motor off with the handle bar ignition switch. I have checked all the wiring connections from the ignition switch to the electrical box in the front and checked all the fuses. About two years ago I had a no start condition and changed the ignition switch and it was working fine when I put it away last fall. Two questions, can it be another bad ignition switch? Is there a known problem with this switch?
