hey guys
quick question here, this weekend I'm planning on pulling my
pump to determine if this is why my motor wont turn, I can
not even turn the flywheel by hand so.... When
the pump is pulled out should I be able to turn the pump by hand ?
once pump is out, should i also be able to now turn the flywheel
provided the motor is not seized or hydrolocked ?
if it does turn it suggests that my motor is seized or hydrolocked would
this be the correct analysis ?
I have removed the starter already just to ensure It wasnt
jammed up causing the motor to bind and not turn, my next
step as stated above is to check the pump.
Any thoughts would be appreciated.
