I would start by cleaning the Post on the safety lanyard. It is beeping and saying it isn't connecting to the Mpem, (Multi Purpose Electronic Module) It needs to beep 2 times to let you know it is ready to start. Clean the post and cap with soapy water. Don't use any grease of lubricant on it as it needs a clean connection to make contact. Connect the lanyard to see if it is making a connection. 2 beeps and it's ready to fire up. If it continues to do this after it is cleaned you need to check the post to be sure it is ok.
Safety Lanyard Switch Verification;
If 2 short beeps are not heard when installing the safety lanyard, disconnect the switch wires.
Here is the proceedure to test the lanyard post.
 Safety lanyard removed;
 connect the test probes to switch Black and Black/Yellow wires. It’s an open circuit, there should be no continuity.
Connect one test probe to the   White/Gray wire and the other test probe to the switch terminal. Measure resistance, it should be “0” ohm. Connect one test probe to the Black wire and the other test probe to the switch ring. Measure resistance, it must be close to “0” ohm.
Safety lanyard on switch; connect the probes to switch Black and Black /Yellow wires. Measure resistance, it must be “0” ohm.
Timer Verification;
The timer is integrated into the MPEM. Always confirm that the fuses are in good condition. To confirm operation of timer, remove the safety lanyard from switch. After 5 seconds delay, depress start/stop button once. The timer should stay on for 33 seconds (for example, the gauge(s) will be activated) and than turn off.
I hope this helps you out.
Karl
