Thank you waterluvr. Your pics and directions made taking this apart easy, everything went well it only took me 45 minutes. And that was only because I took my time and tried to be careful. now for some pics of the damage. Wow, I can't believe the size of the rock it sucked up and jammed in the impeller. I have no doubt the impeller and wear ring need to be replaced.
View attachment 26669View attachment 26670View attachment 26671View attachment 26672View attachment 26673
I was wondering about the pic I took of the damage to the area outside of the pump you can see in the picture. What are your thoughts on that? If you don't mind let me know everything I will need to replace. Thank you
Well, the impeller is chewed up pretty good along the edges but the critical areas of clearance at the tips don't look to bad. Definitely going to need a new wear ring (and round neoprene mount seal).
I have cleaned up a few rock damaged impellers lately that surely were in worse shape than your's and they are working just fine according to the before and after rides from their owners if you're so inclined to spend some vice, hammer, file and time to attempt getting the rough spots out of it and straightened. The critical area's are the discharge side of the pump and blade edge clearance to the new wear ring, .040" being max and I can attest to a new oem wear ring and a new oem impeller pn# 20416007 having a nice snug fit with .007" all the way around on my '97 Challenger.
I like the stock impeller, it pulls the boat right up on plane sharply with a healthy load on the boat from a full load of passengers or tubers/skier and the top end speed is plenty with it. I think that clearance to the wear ring is really critical with these single engine boats to get the most efficiency from your pump.
I considered sending my old damaged impeller out for a complete rework as it's significantly less money than buying new but at the end of the day I wanted to know exactly how that boat responded and ran with everything being new in that pump housing and what clearances were related to that performance level as I bought mine used just as you had with no baseline for performance expectations.
You'll need to get that silicone and old neoprene gasket cleaned off the opening to the ride shoe, maybe smooth out any gauges in the aluminum. Do I see some dime sized nicks in the gel coat from the rocks? Might want to touch those up with some epoxy or resin to seal the glass fibers also.
Have a good look at the splines on the driveshaft and make sure they aren't worn, also now is a good time to go in the engine bay and find the gray plastic cover that is over the pto shaft and carbon seal and remove the two plastic wing nuts and washer on each side to remove it. You need to grease those shaft splines at the pto fitting, just a little bit you'll see the pto boot fill and swell and inspect the carbon ring and seal boot because if any of that needs attention it's definitely worth doing now while the pump is apart and you can slide the drive shaft out if need be.
Hope that covers it, ask away if I lost you anywhere.
On Edit: Before I forget, please reference the torque spec in the manual for the steering control nylock and the rest of the control end cable components when putting it back together. Easy does it on those, they are torqued to inch pound ratings so things don't compress and break. I understand finding replacements is an issue with some of these boats now. Just snug it up if you don't have an inch pound wrench, easy does it.
