'97 Challenger, need to rebuild the carbs & pump
Waterluvr
So I was out today and the boat started acting up after an hour or so (was running really well the last few times out), surging from transition to idle / full throttle finally not building more than 3500 rpms. I checked the rectifier and unplugged it no love, neutral safety switch is good and the boat will start and idle fine every time just no top end all of a sudden. Good compression, 152 / 155 psi. and good fire on both wires and plugs and nothing is getting hot.
So, carbs and fuel pump? Might as well, they look like they haven't had any help for a long time. Is there a complete kit to cover both carbs and the fuel pump? Mine has the pump just to the right of the carbs with it's own impulse line.
