Hollymax0428
I've done a bit of research into changing the current single Seadoo 787 110Hp motor to a something like a 175 - 200 Hp using a powerhead from an Outboard similar to the Mercury Sportjet used 2002-03 etc, only retaining the Seadoo Jet pump rather than use the Mercury Pump.
Some points that I have to overcome;
1. I need a right angle drivebox with something like a 1.5:1 ratio to convert the 5,000 - 5,500 outboard motor rpm to around 7,000+ at the impeller.
I could use the gears from the outboard only reversed in a fabricated gearbox.
2. The exhaust from the powerhead needs to come from the bottom of the motor up like the sportjet setup instead of down like an outboard, and in Australia no one has any used parts, so other than buying new which would be around $2500 + just for the Adapter plate and expansion chamber, I may get stuck having to fabricate that as well.
3. The 140 mm jet pump may not be big enough to get the extra performance without trying to fit a larger pump, unless I can get an impeller to suit the 140 mm with the increased horsepower or lift the impeller rpm to 8,000 rpm (if it will take that sort of increase from the normal 7,000 rpm).
4. I need to mount the engine, but seeing the Mercury Sportjet just bolted to the floor via the Jet Pump housing that shouldn't be an issue by still using rubber mounts to lessen vibration.
Can any one offer and information or advice on the above points or any other obstacles I may come up against.
I'm trying to make it as less complicated as possible.
Powerheads in Australia second hand bring around $3500 + and another $1000 maybe to get the drive box and exhaust setup done. I'm used to fabricating machinery so I'm not phased by having to do that.
If I can get the Adapter plate etc from the USA I would probably have to use a Mercury motor rather than onother brand, but not having to re-invent the wheel may save some time and worry, so if anyone knows who I could contact in the USA to get a second hand Adapter Plate & parts I would appreciate it.
P.S. I realise it would be easier to just get another boat with a bigger motor, but I like the layout and size of this one and there is probably a jump of around $10,000 - $14,000 in price :ack:.
The 110 Hp motor has just been rebuilt so should bring part of the difference to upgrade, or I could fit it to a Jetski with a blown motor
