wow, yes that fiberglass is torn up, looks like something was sucked up and spun around with the impeller...
you can use MarineTex to fix that...
I`m pretty sure that water pipe is replaceable #15
http://www.sea-doopart.com/oemparts/a/sea/500cfc9af870021b3c6a8009/propulsion
was the hose disconnected prior to pulling the pump? it looks like it came out some before it snapped.
don`t forget to get a new pump foam seal and use The Right Stuff Black RTV or Ultra Black RTV sealant when assembling.
Look in the shop manual to see where the placement of the sealant is...
