Lifted5.4Lariat
Hey my names Brent.
Been having some tough luck with my 97 challenger..
First off I had a clogged oil filter which ended in a top end rebuild.
Then I had really bad cavitation which was the carbon seal.
Now i'm having a bad bog around 5k and it will never go to WOT strait off the line and it always bogs at 5k.
The symptoms are that it will just stop revving up at 5k. If I bring the throttle back down to 4500 and punch it SOMETIMES it will go up to WOT at 7k, but sometimes there is zero difference and it will stop right back at 5. If I have a 400+ pounds it will ussually take 2-3 mins to get it above 5k and if its just me maybe 30 seconds. Sometimes when i'm toying it it seems like I have to work it up. For instance, after bogging at 5k and dropping down to 4500 then punch it it will climb to 5500 then hit a bog and drop back down to 5k then I drop the throttle down to 4500 and punch it to 6k. This will sometimes work and sometimes it will act like it is going to climb all the way to 7k but then it hits a bog and drops to 5k.
Rave valves have been cleaned twice since the rebuild and I have noticed some oil under the cap and even under the piston of one. I cannot see any visible damage to it, but it is an original as the other rave setup looks new compared to this one. Could this oil be the cause of my problems?
I will note that I am on my third tank of 87 octane fuel since the rebuild. With my first tank I ran it with 2.5 ounces per gallon in the fuel on top of the injection and I dont believe there is much if any oil still in the fuel. However, when the engine bogs there is a significant amount of smoke coming out the exhaust, but when I look at the plugs they dont look oily at all, at least compared to the ones out of the first tank of fuel. Oil injection tank doesnt seem to be going down much either per tank of fuel, an inch max. Why would it be smoking so much? Once I get it to WOT by messing with the throttle it seems to smoke a normal amount.
The previous owner said he had the shop rebuild the carbs, all fuel lines are new and black, and the engine bay looks extremely clean. It was a very well taken care of boat and this problem has me stumped.
What do you think it is/ suggest I do?
I really would like to get the boat running well before the heat of summer gets here!
Thanks, Brent :willy_nilly:
