What is "a very long time"?
Are you talking 3-5 seconds, or 30-45 seconds?
I have the same boat, and it is a little slow out of the hole, but it will come out pretty quick.
If you leave the vts in any one position while taking off, it will come out even slower.
I found the quickest way out of the hole is to give it immediate 80-100% throttle with the vts back in "ski" mode, then over the course of about 3-5 seconds, slide that vts forward until you are in "speed" mode. Just leave the throttle alone after you push it forward. Once you are planed out and the vts is forward, then you can pull back on the throttle to adjust your desired speed.
But this is all worthless info if your boat takes more like 30-45 seconds to plane. Then you may have a technical problem, not a technique problem...
Then I would suspect wear ring, but you mentioned that it is new.
Do the rpms go up to 6500 or so when you floor it?
