Hollymax0428
Can't believe it. After all the dramas on my last post '97 Challenger slow... ' & rebuilding the top end of the motor.
Took the boat out last weekend, Saturday, running in the motor for around 2 hrs with brief periods of opening it up.
Sunday did 2-3 hrs not going too hard but using it for a bit of tube towing.
This weekend Saturday did similar, around 2-3 hrs towing the tube off and on, so hard for a start but then runing around 5,500 - 6,000 for fairly short periods.
Sunday did around 2 Hrs and every thing running fine then the motor cut out.
Fuel was low so turned onto reserve then went for another 10 minutes and motor cut out and wouldn't start again.
Checked the compression when I got home and MAG cylinder 150 psi, PTO cylinder 5 psi.
Last time the PTO cylinder was the good one & the MAG cylinder had the worst but both still had around 100 psi. Now one cylinder has virtually no compression.
Have no idea yet until I pull off the head and probably cylinders what has gone wrong. Motor wasn't showing anything or sounding wrong. Just cut out twice, prior to that was running well.
I checked the compression yesterday and was on 150 psi both cylinders.
Maybe the boat is jinxed :reddevil:
