as far as I know seadoo doesnt sell an assembled pump. even the shops assembled the pumps.
You would need a few SD tools to simplify the install of the bearings and seals. bc if you canibalize any of it, it won`t last long at all..
now you have to weigh in the cost of parts VS a complete pump...
currently I`m running 2 complete pump assemblies from SBT with my solas 15/21`s.
you will still need an impeller tool to remove/install an impeller.
I have the same theory, extra pumps just in case one gets lunched...
I`m also using SBT`s delrin wear rings for a while now, no complaints...
I would think the stock/OEM impeller would still work for you. If you pitch down, you`ll lose top end speed by a few MPH. The twin engine challengers have enough umpf to pull a tube as is... however if your really loading down, then go with a smaller pitch.
