hi all,
purchased a 97 Challenger 1800 with twin 110s this spring. Had it on the water only once so far and after a short while I noticed that when idling for a bit it would start continuous beeping. I shut if off and restarted and would be ok for a while as long as I had it rev'd up then back to beeping when idling. I realize from all manuals that continous beeps is overheating (in some newer Sea-doo's it relates to oil but should not be the case here)
Now, I'm checking it out on land connected to water. Water flow is perfect, disconnected sensors and also checked temp sensors - they work great (took them off to test in boiling water), engines are both definitely not overheating and sensors are functioning normal.
When I start either engine, after about 20 to 25 seconds, I get a continuous beeping.
Absolutely everything else works great.
Something in the MPEM???
Anyone recognize this?
thanks for any assistance
Ryan.
Ryan.
