seadoorider9999
Ski ran fine before, but.... now when I go to start, put the key on, get gauges to light up, and trim will move up and down, but no start. I don't get any crank at all from the starter. The beeper that recognises the key has never worked, so I don't know if Im getting one or 2 beeps.
-All fuses OK
-Start button has 2 wires, I tested them, one gets power, and the other is a ground. When pressed, the power goes off (seems weird but I guess thats how the mpem reads it, although if this is the problem let me know!) So start button is OK
-The rear electrical box has good ground, and has power coming in from the battery, that is hot, then a 4 gauge wire going to the starter that is located next to the hot wire coming in. But even when key is on, the wire going to the starter gets no power when start button is pressed.
Seems to me the mpem is not recognising the key, and therefore wont give the starter juice, but would it still let the trim move and gauges come on when the start button is pushed??
Anybody have any suggestions? Thanks!!
-All fuses OK
