It has been a while since the last update. We have been waiting for the replica decals and trying to find a close replacement vinyl for the seats.
So today the fuel lines were replaced, exhaust bolted down, the wiring was all hooked back up, the rave valves were installed.
The pump oil was changed. It was very black but no signs of water.
We use mobile 1 75w 90
The o rings were hard and 1 had a chunk missing
They were replaced with these. We bought a large oring assortment pack from harbor freight. They are a little thicker but work fine.
Whoever changed the pump oil last screwed the fill plug down too far. It was almost bottomed out. It only needs to be flush with the housing like this
The plastic looked pretty faded so we busted out the wipe new
These pictures are bad but you can make out the fading
Started wiping the center
I need to hit the corners with some acetone and qtips to get all the crud away but as you can see it is a big improvement.
