got 96 XP, started and ran but bogged down (but kept running) once you got up and running. Wouldn't stay on plane. Had original hoses. Replaced them and gunked up filters, cleaned selector, rebuilt carbs, cleaned up RAVE valves, even removed fuel tank and cleaned it. Now it starts, but any throttle and it immediately stops running. Went back through all hoses, selector, even took carbs off and went through again. Still does same thing. So it's worse than before.
Last night, pulled rear plug boot and it kept running. Hmm. Pulled front boot and it quit. Swapped plugs, and pull either boot and it quit. So maybe a bad plug? Replace both plugs today. Pull either boot and it stops. Cut back wire 1/4" as suggested other places and no improvement. 150 psi compression both cylinders.
Any ideas? The main things I've worked on have been carbs, hoses and the RAVE valves (though I did that before the hoses and it was running as original--don't think that's screwed up). Any suggestions? Does the weird plug thing last night mean anything?
