Chaseman24
Hi all,
I'm brand new here and have started having trouble with my XP. Last season, it started to get a bit flaky when connecting the lanyard, sometimes we'd get the beeps and it would start fine, other times nothing. Once it beeped, all was fine. This year, no beeps at all.
Pressing the start button still activates all the gauges and if I press it 5 times I get the 1 short been followed by 1 long beep.
I've tried the following tests and here is what I've found:
I'm hoping this verifies that I'm just dealing with a bad post? If this is the case, where would you suggest picking up a replacement?
Thanks,
Chase
Safety Lanyard Switch Verification;
If 2 short beeps are not heard when installing the safety lanyard, disconnect the switch wires.
Safety lanyard removed;
connect the test probes to switch Black and Black/Yellow wires. It’s an open circuit, there should be no continuity.
Open circuit
Connect one test probe to the White/Gray wire and the other test probe to the switch terminal. Measure resistance, it should be “0” ohm.
Measures 0
Connect one test probe to the Black wire and the other test probe to the switch ring. Measure resistance, it must be close to “0” ohm.
Measures 0
Safety lanyard on switch; connect the probes to switch Black and Black /Yellow wires. Measure resistance, it must be “0” ohm.
Measures .569k
Thanks,
Chase
