I apologize in advance for the length of this post. I have done a significant amount of searching and have not found this specific problem yet...
I purchased the ski about two months ago and at that time I check compression, which was at 150psi on both cylinders.
Boat ran great prior to the carb rebuild with the exception of a low end hesitation. This prompted the carb rebuild. I completed the rebuild and crank it up, it started great out of the water and after a few quick throttle jabs I figured I was off and running again.
I put it in the water and could barely get it to run. Carb adjustments are set to 1.5 LS and 0 HS. I cranked and eventually the starter went out. I had figured it was on its way prior to this as well. Order the starter, slapped it on and cranked again. It started right up but didn't sound healthy at all. After a few more tries the boat quit running all together. It still cranks freely.
I then looked at the exhaust and found a decent amount of oil (sticky) in the exhaust pipe. This prompted a compression check which revealed that while cranking the compression was between 130 and 140 but when I stopped cranking the compression would fall to 0 immediately. I have tested the compression gauge and it is not faulty. I pulled the head off and inspected the tops of the cylinders and they were black but I did not see any visible where. However, from the sounds of things the wear is normally in the sides of the pistons.
Any thoughts? Would a boat loose compression on both cylinders like this at the exact same time? Any help at this point would be very much appreciated. Thanks!
Chris
Chris
