96 xp ignition timing
96 xp 800
I bought a 96 XP 800 and put a aftermaket pipe on it made by "FACTORY". The dealer gave me nothing but the pipe itself. I bought a gasket and put the pipe on and have rejetted the carbs. I also put aftermarket flame arrestors on it and put two new carb kits on the carbs. I am still having problems getting it start in the water. Once I do get it running it sounds like it is misfiring. Upon doing some homework I realized that the pipe was suppposed to come with a different rev limiter. I guess i just need to know if putting the pipe on without the recomended rev limiter will throw off my timing and if i buy the recommended rev limiter will this fix my problem?
You check the timing with a timing light. Just follow the manual. Installing the Factory Pipe will not affect the timing. Is it a spec 1 or a spec 2 Factory Pipe? If it came with a manifold, it's a spec 2 and should have included a water injection solenoid and module. You may have problems not related to the pipe. Have you checked your rotary valve clearance?
Chester
96 xp 800
Thanks for the tip. The pipe did come with a manifold but no water injection solenoid or module. I am in the process of trying to find the solenoid and module but it is somewhat expensive. Do I have to have them? I will look into the rotary valve clearance as well.
