skewba98z28
Ever since I bought my XP it has had what seems to be a blubbering rich sputter when you first go WOT for the day. I usually idle around for 2 to 3 mins to allow the motor to warm up some (could be a issue) and then I'll slowly transition the throttle to WOT. Then when I get past 1/2 throttle to wide open it sputters like its rich and won't get up on plane. I can do that a few times and pull it back to 1/2 throttle and then mash it again WOT and it will "clear" out and run like it should the rest of the day. When its sputtering I can slowly pull the choke out and it dies instantly and doesn't pick up any rpm before it dies so i'm assuming it its not lean. Its not hard to start when I first arrive to the ramp. It takes slight choke like most and it fires right up. Doesn't smoke real bad either.
To try to remedy this and for piece of mind I rebuilt the carbs including needle and seats, installed new plugs, and installed a new fuel selctor as it used to be bypassed. Needles are at stock settings (Low 1 out and High 0 out) and the pop off is around 26-28psi. Before the pop off was the same, but the needles were (Low 1 1/4 and High 1/4 out) I also pulled the plug boots, cut the wires back, and reinstalled them.
I put new plugs in it and gapped them correctly before I rebuilt the carbs and that didn't fix it. It acutally seemed worse. The old plugs were gapped wider than the new ones. Also I could get it to clear out and run smooth for a few seconds at WOT and then it would go right back to sputtering. I could ease the choke out at WOT while it was sputtering and it would die instantly.
Today was the first day on the "new" carbs and it fired right up at the ramp. I idled around a minute or two and at this time I eased out on the choke to check for a lean low end and it died instantly without picking up any rpm. I fired it up again and blipped the throttle a few times and started slowly transitioning up to WOT. It was smooth until right before the raves like normal. After the raves opened it started doing the same sputter it was doing before. Ease the choke back and it dies instantly so its not lean. After a few tries it cleared and ran great. I ran about 2 gallons of fuel through it, the plugs look fine, cylinders feel normal heat wise, and the plugs do also. The rpms follow the throttle with no hesitation anywhere other than right when the raves open up which is normal. It seems all is well once you get past the initial sputter....
Is there anything i'm missing here to try to remedy the first WOT sputter or is that just the nature of the beast. The ski had been sitting about a week so i'm going to try it again tomorrow and see what it does. My spx does the same thing but only for a second or two and it clears out.
One thing that I could think of is my oil pump adjustment is set to the rich side so its possible i'm oil fouling the plugs as i'm warming the machine up??????
