Hello all,
I am trying to diagnose a long running issue on this dang XP that I have. It has been fighting me for probably 2 years and I am super close to throwing in the towel on it. The issue has slightly transformed which can be heard by listening to the first video and then listening to the second. It cuts in and out like it is just dropping spark. It used to almost be like a rev limiter that was at like 5200 RPM and when you would hit a wave, it would let it rev out until you bring the throttle back down and try it again and it would do that same once again. Now it is just stuck at maybe 5,000 rpm and if you hit a wave it might let it spike for 1 second but comes back down to being stuck at low rpm. It goes about 40MPH when it is doing this and will not go any faster.
I have replaced the following with no success:
entire E-box
Stator/mag cover/trigger
mag cup
cdi
swapped another set of carbs on it and it didnt change the issue
voltage regulator
Probably other stuff I'm forgetting
Please help!
entire E-box
mag cup
cdi
voltage regulator
Please help!
