96 xp choking out
burellii
i just rebuilt my pump and went to water test it today. it ran fine then all of a sudden at WOT it seemed like it was choking out. lost power. if i tap the trim up or down it seems to rev a little but goes back to the same problem. if i turn it off for a few seconds, it ran fine. the problem seems to come and go. any solutions????
:agree: Pull the pump and make sure the impeller is not too tight. Make sure thrust washer and bearing are not wedged in shaft groove. To check,
manually pull and push jet pump housing, some axial play must be felt. Also make sure you torques it to spec and it spins freely. Torque is 52lbft/ft
Do you have a seadoo shop manual? If not here’s an idea for you. You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
the pump is fine. i had the problem with the thrust bearing and washer getting wedged. but i fixed that before i even put it back in the machine. i have the shop manuals. this actually started before i rebuilt the pump. and 2 of my buddies xp's are doing the same thing. could it be a carb problem??? when i ran it today it ran great when it was running.
