coreyardis
OK, here's the story. I let a lets say overweight cousin ride my XP. It flipped he couldnt get back on andit filled with water. Towed it in put it on the trailer and got all the water out. Restarted and finished the day of riding. Got home and checked it out some more. Found the coils box filled with water, drained and cleaned everything. It started and ran fine. Parked it in the yard 2 weeks while I was at work, came home and would not start, turned ove no start. Changed plugs, trimmed tghe spark plug wires back, they looked bad. It started, ran for like 2 min and died. Now it will start and run 2 min and die. Aftrer it dies there is no sark. Took the plugs out and spun it over with the plugs in the wires and it is firing for a few min then quits... I am lost. The coil was corroded a bit, I cleaned the corrosion and cleaned with electra clean, same thing. Is the coil bad or is there somthing else it could be? Thanks for any help.
