96 xp 800 no trim
stizzle93
just got a quick question, trim worked fine all last season until last day out, when i press up on the trim button i hear a clicking noise but no sound when down is pressed, is my vts motor bad or do i maybe have a bad fuse or bad buttons? thanks for your help!!
You could check the fuses, but it sounds like either a corroded VTS or a bad VTS motor.
Karl
cleaned all the connections got it working again thanks. where can i find some proformance parts for my ski nothing crazy just maybe some exhaust and maybe so high speed jets or whatever that is to get like 3 or 4 more mph i ran 63 trimmed in sweet spot on gps on smooth water, and i weigh 215 lbs but i wanna hit 65
The stock impeller is good for around 60 mph. Go for an impeller that has a higher top end. There is plenty of room for play in that XP. It is plenty powerful enough for a steeper pitch for higher top-end speeds.
Call Dave at Impros for a recommendation for a faster impeller. 909-370-4900 or http://www.impros.com
