I have a 1996 SPX that suddenly stops. I can be running full speed and then the engine stops as if the key was pulled out. When I try to start without pulling off the key, I get a long beep.
I simply pull the key off and then put it back on. I get the double beep and then it starts up again. Sometimes this happens every 5-10 minutes. Other times I can run the entire day without any problems.
I am sure that the key is not coming off. I have even held the key in place with pressure and it will suddenly just stop - again at higher speeds. The ski usually stops when you are at a speed above idle on plane.
I have replaced the key sensor but I am still having the problem. I have put dielectric grease on all of the connections and made sure that the connectors are tight but this has not fixed the problem.
Any ideas on what may be the problem?
