96 SPX Electrical Issue
Adskie
This is first post here, will try to be as thorough as I can.
I have a 96 spx with a rebuilt rotax. It's super clean, but having some electrical issues. I had it out on the lake yesterday, and first time it started great. Each time after i had to run the starter a bit longer to get it running... theLast time I went out to start it, I had to run the starter too much and the it just stopped turning over. Nothing when you push the start button. So I parked it. When I checked the battery voltage, I was down to 11.65v, so I pulled it out and put the battery on a 2a charge for a couple hours. Went back to check a couple hours later and voltage was still at 11.65v. My battery is smoked! The battery an AGM and is brand new, just picked it up a month ago. And I replaced the rectifier this spring as well. What would cause my ski to smoke the battery? Any help on what to do next would be great!
Could be a case of a bad battery, they don't make them like they use too! Before you toss it, take it to auto store and have them load test it. Could your charger be bad?
Thanks for the reply Grim! It could be a bad battery, though it's worked fine up to this point, then running it on the lake a while, I wonder if som we thing grounded out the battery and caused a cell to go bad.
I've used the charger on many other batteries so I don't think the charger is bad. But I'll be heading home from the lake tomorrow, and so I'll put it on my known good charger to confirm.
Could it be my rectifier? And what test would confirm the rectifier to be bad?
I will also take and test the battery as well.
To test rectifier you can start ski, put a meter on the battery and see voltage:
idle = 12v range
at 4500 RPM = 13v range, no higher than 14.5v ish
if it stays in the 12v range at 4500rpm bad, if it goes above 14.5v ish than bad
let us know the numbers if it is close.
Also don't let the ski run too long out of water.
Awesome, thank you both, I will be home tomorrow afternoon, will get a new battery, will test voltage readings and report back.
Also I have the garden hose attachment to run out of water so I'm not concerned about running on land.
Thanks!
Thanks!
The hose doesn't cool the drive line, which is cooled while in the lake. So be careful. It is not recommended to run it more than 20 to 40 secs out of the water
I load tested the battery this afternoon, confirmed it's bad.
Load: ~11.5v, 131cca
This battery was brand new in June.
Purchased a new Battery today at fleet farm (road runner AGM ETX16L)
Hooked it up, and tested the started, met with only a click. I replaced both the starter solenoid and the rectifier this winter.
Also to note there was still some water sitting in the bottom of the hull, I drained it out, but it's been sitting there for a couple days. May need to air it out. The ski died on the lake, and wasn't a lot of water, so I'm not too worried, new wear ring last year with not many hours.
Not sure what to do next?
Jump the solenoid with a screw driver if it turns over your solenoid went bad. Probably because your battery was weak and caused the solenoid to crap out
I had a few minutes over lunch today and jumped the solenoid, all I got was sparks...does that mean starter?
I would check your starter and bendix, might of got stuck. If it is bad try to get an OEM unit or a rebuild kit, aftermarket starters are not high quality.
Great, thanks for the suggestion. I have a 96 SPX, so doesn't have the bendix. I will look for a rebuild kit or OEM starter and work on next steps!
No, just no. Please steer clear of SBT. Stop Buying Trash
Best starter is going to be OEM or rebuild your OEM. 98% of the time it is just the brushes that need to be changed.
The reason I am so against SBT is because I have been working on these for over 30 years and am tired of people coming here and getting burned by SBT and inferior parts. I want you to keep these skis running.
Thanks for the reply mikidymac, I will steer clear of SBT. I will find a kit to rebuild my starter and hopelly smooth sailing from there...
Update, just purchased a Caltric rebuild kit, should be here by the weekend, so I'll rebuild and report back after the rebuild and install. Thanks for all the great feedback!
coming back to this thread -I've appreciated all the feedback so far! I was working on the starter this past weekend and had a really difficult time getting the c-clip off of the starter to fully disasemble the shaft/gear. i did finally get it pulled off. and now I'm having an even more difficult time getting it back on the shaft. that is the last piece I need to reassemble the starter. Any suggestions? I've seen a clip on a guy who used a long socket thats close to size to get the c-clip back on. but not having much luck with that...
