96 spx blowing fuses
vooch
I bought a used 96 spx recently with a non functioning trim. I took the vts wiring apart and unclipped the wires for diagnosis later. As I am trying to get the machine running on the trailer to diagnosis the vts I am continually blowing fuses on the 7.5 every time I put a fuse in it and I am occasionally blowing the 5 amp fuse as I am running the engine on the trailer. It appears as if I have very clean terminal ends and good clean connections on the battery. I have had the machine running for intervals of 5 minutes on the trailer with water pumping through engine fine. It has great throttle response and idles nicely, but then will occassionally blow the 5 amp fuse. I am running it without the 7.5 amp fuse, because I cannot keep that fuse in the machine at all. Any suggestions??
