So bought this speedster this spring. Have had it out maybe ten times. My wife is going thru chemo so we havent used it much or gone fast most times.
Past 2 times out the plugs have fouled.
Took it to seneca lake this weekend. Got out the first time plugs fouled, found the water inlet tube was cloged "maybe spider" blew threw out in the lake. the BEEP was almost constant untill it started.
Took out again made it about a mile andkilled battery couldnt get it started had to be towed back.
Got it home read up a little on whats up. First bad thing is compression... one cyl is at 90 psi, and second is at 120.
The next issue was the no spark. Pulled flywheel cover and found this at the bottom
Sooo... what next. I wanted to pull the flywheel but the gas tank is in the way of my puller, any help there would be aprreciated.
