96 sportster ground wiring
n-mod
I am just getting my boat back together after a rebuild, but I can't seem to figure out the ground wires. I wasn't the one who took it apart so I don't know how it goes together. I have one ground coming from the ebox and one coming off the engine. Which one hooks up to the battery and where does the other one go?
If anything like my 787 ....battery Negative to starter ground, Pos from battery to solenoid, positive cable from solenoid to starter positive connection.
hope this helps.
The difference is the ebox has a ground and the engine. I have two grounds to hook up. It almost looks likes its battery negative to engine ground and engine ground to ebox. But I just want to make sure.
Nevermind, it looks like its supposed to connect to the spark plug grounding plate and go to the ebox. The one from the battery goes directly to the stater bolt.
