96 SPI 587 blowing 15 amp fuse
nybs
Hi all. I'm new to this forum as my wife bought an old sea doo for my son. We had a lot of issues with the usual stuff when we brought it home which we figured out after a bit. Our latest issue is blowing the 15 amp fuse. Has happened four times in the past month. Seems to happen when the ski gets tipped to an angle.
Today I removed the cover to the magneto/ flywheel case and found a bolt shaft (missing the head) in the bottom between the cover and the wheel. I put it back together and haven't tried it yet. My question is....., if the bolt would interfere with the flywheel movement, would that blow the fuse? Also, where might that Bolt have come from?
Thanks in advance. you guys are awesome.
