Hi all,
My 96 Speedster was having some cavitation and a small amount of water in the hull so I decided to tackle replacing the carbon seals, wear rings, and impellers. Using this Forum (thanks!) I've learned enough to have the pumps ready to reinstall, but I am concerned with how the drive shafts fit into the new impellers (drive shafts are out). I purchased Skat Swirls with new nose boots. The new impellers turn freely and smoothly. When dry fitting the drive shafts into the impellers with the rubber bumpers installed, the drive shafts fit nice and there is just enough gap between impeller and drive shaft lip for the nose boot. After I install the nose boot and the grease the impeller and drive shaft splines, the drive shaft slides through the nose boot and into the impeller and the splines align, but it backs out a half inch from what seems to be air pressure. I'm thinking the air displaced by the incoming drive shaft cant escape the nose boot sealing against the drive shaft. I have to push with maybe 20 lbs to pressure to seat the drive shaft properly, but when I let up, even after a minute, it backs out a bit. Should I install the pumps like this and figure the pressure will escape quickly with use? Is this normal or do I have a problem?
Thanks in advance for any advise.
