Mooze
Alright info....
I bought a 96 speedster hasn't been ran in 2 years
Eng 1
fully assembled cyl 1 145 psi cyl 2 150 psi.. Was able to use some starting fluid to just see if it would fire (it did)
Eng 2
Bottom end replaced with used one, upper half just slapped on all new gaskets and o rings. carbs and exhaust removed. By previous owner... Compression Check cyl 1 140 psi cyl 2 90 psi... Took cyl 2 apart had scaring on the walls.. Honed it put it back together.. Cyl 1 135 cyl 2 120 (not sure why the drop in Cyl 1 psi) Rings in cyl 2 met specs for gap.
Gas
Mixed been in there about two years ( plan on draining ) Fuel gauge doesn't work (gauge or wiring?)
Oil / injection
Tank empty / injection removed ( have pumps) but they cut off the lines so would need new ones
Electrical
All but bilge pump seems to work. He did some sort of messed up wiring and cut the wires and tried to do his own thing (would be nice to have a full wire diagram)
Hull / seats
Great shape
Ok I think that fills in the back ground
So here are the questions I have. Of course any other info any body would like to supply would be wonderful too!
A) with the oil injection removed what kind of oil should I fill OIL tank with?
B) What kind of gas / oil / mix ratio should I use for it? (maybe next season look into putting injection back)
C) I'm not sure if he ever aligned the engines should I tear it all down and do it? (pay the 150 for the tool or?)
D) The bilge wires have been cut up, does any one have a wire diagram for it?
E) Should I try to run the engines after I get em back together with out tearing apart carbs ( if it aint broke don't fix it?)
F) After i get all the electrical and engines back together can I just power wash the eng compartment and boat?
G) Also, the two points on either side of the boat is that where you hook up water to run the boat? White plastic / black screw on cap. I'd hate to ruin the engines if they aren't already!
Um... Those are all the questions I have... Any do's or Don'ts would be nice ... Thanks ahead of time
A new LOST jet boat owner!
Eng 1
Eng 2
Gas
Oil / injection
Electrical
Hull / seats
Great shape
