96 Speedster, PTO FLYWHEEL AND SHAFT REMOVAL.. NEED HOW TO, HELP.
Well, since it's stripped. Just remove the rear PTO spark plug, spin the pto by hand CCW until you reach top dead center on the piston. The rotate CW maybe an 1/8 of a turn. Lower some clothesline down into the cylinder, probably about 5' worth, then rotate the pto CCW again until it binds up, then use a pipe wrench to twist the PTO off the crank. Install will be the opposite, but I would get a solas brand impeller tool for a 140mm impeller (about $14 shipped on ebay) and then install the new one and torque it with that.
http://www.ebay.com/itm/Solas-Impel...m25d91b4a17:m:mkeTQeMbwBARTsm5KUnoWRw&vxp=mtr
Shaft removal
Before you pull the pump, you need to disconnect the c clip on the driveshaft (See video below)
Pull back on #8 it will expose the o-ring or C-clip if it has been upgraded. Pop the clip or o ring off.. Then remove the pump, steering cable and reverse bucket etc.... Pull pump, remove driveshaft, remove PTO. Probably 1 to 1.5 hours work (or much less if you had done it before) to get the job removed .
convert
[video=youtube;97qJA8v1MZk]https://www.youtube.com/watch?v=97qJA8v1MZk[/video]
