Are you sure the gauge is bad? Usually the sender is on the fritz.
Resistance should be 0~90 I'd guess, but I never measured a 96 so don't know absolutely, I think they were all the same? Would be same as the ski for that year.
By touching the two sender pickup wires together, you can test the gauge, should go full scale. Toss a 50 Ohm resistor on there and should be ~1/2 scale.
