Hey guys...first post here:cheers:
I was out on the lake today and ran into a problem with one of the 787 motors in my boat. Everything was good and running fine, and then the motor cut out. It will start back up fine, idle, and run at a low rpm, however with any kind of load the engine shakes more than it should, and then slowly tries to die until I back it back off to idle. I limped the boat to the dock, and once I got home I hooked the hose up to the motor that is having problems and ran it in my driveway....it seems to be spitting out a lot of dirty oily water. The good motor is spitting out clean water. Does anyone have any idea's what this could be? I plan to take the boat in this week and have it diagnosed if I happen to not get a response. If there is anything you recommend I check...i'm all for it (i'm pretty mechanically inclined).
Thanks!
Thanks!
