So I have a 96 speedster that has had this problem that seems to be getting slowly worse. At first it would only happen a few times then it would allows the engines to crank until started but not it non stop.
Both engines have the same issue. When you go to start them they will only crank for about 2 seconds not giving them enough time to start then cut out. Pull the lanyard out and same thing. This will happen over and over and over until all a sudden it lets them cranks over for a while until they can start up. Once one gets running I can then get the other started just fine. I can ride all around the lake just fine but if I stop and kill the engines I have to go through this entire process again. This has been going on for a couple of months now. Finally its getting to the point that I should probably get this taken care of before I get stranded. Any ideas? Thanks.
