Here's the original thread from last week.
http://seadooforum.com/showthread.php?t=4256
What I've been up to-
I repaired the damage in the channel before the impeller on the right side. I did this with some epoxy and smoothed it out to make the surface flow correctly again. I didn't repaint in there because I don't really care what it looks like, as long as it doesn't leak ( it doesn't)and performs like it should.
I tore down the jets on both engines. The right side had no seal on it, the left side did. I installed new seals on both jets.
While I was in there, I figured it was a good time for new impellers. I used the Skat Trak 14.5/22.5s with new grommets.
The wear rings were recently replaced on the boat, and the new impellers were a scrape-to-fit clearance on them. The gap is now limited to the runout on the prop bearings (not much)
All this, plus I greased everything, lubed all the cables and adjusted them to ensure that the reverse hoods were fully locked up when in forward.
It still cavitates.
Not too bad... the improvement was dramatic, but it still requires easing into the throttle slowly to gain speed, and takes mabye 10 seconds or so to get up on plane, then it takes off. The problem is much worse with more passengers in the boat. We went out today with four of us and a labrador retriever, and it still cavitated fairly bad. We dropped two passengers and the dog off at the sand bar and took the boat back out and it was much improved.
I guess my problem lies in that I don't know what tio expect from it. I've never had a jet boat before, never even ridden in anoither one, so I don't know what it should be like if it were 100%. I've had an XP800 before and ridden lots of other skis... I'm expecting this boat to holeshot like a jetski. Is that possible?
It still cavitates.
