96 SP cranking without key when connecting battery up. Won’t stop running until battery dies or is disconnected. Help.
Austin50351
I just bought 2 PWC last week. A 1993 GTX and a 1996 SP.
The SP starts to crank the second the battery is connected even without the safety switch pressed in. If I push the start button it will fire right up but then won’t shut off until I disconnect the battery or the battery dies.
I also tried disconnecting the small gauge wire that goes to the starter and when I do that it won’t crank at all.
I tried replacing the starter solenoid and the problem continued. I also swapped my safety switch for the one on my GTX and it still didn’t fix it.
I’m starting to think it Is the MPEM.
Any thoughts?
