96 Seadoo XP hard start in water
joeyindahouse
Hi Everyone! I'm a newbie to this forum. I hope you folks might be able to help me. I have a 96 Seadoo XP that has a hard time starting in the water. Starts on the trailer with no problem. I have done alot of work on this great machine. I have replaced the fuel tank (recalled), change all the gray fuel lines out, cleaned the fuel selector, change the external fuel filter, rebuild the carburetors, changed the filters in the carbs, replaced the starter, new battery, changed the jet pump oil, pumped more grease in the zerk fitting on the driveshaft, and cleaned the RAVE valves. I didn't adjust any screws on the carbs. It runs great when I'm able to get it started. It does not bog at all. I have a hard time restarting it after a good ride. Sometime it will start after trying for 5 mins or so. Cranked it so much that it drained the battery. If anyone can give me any advice I would greatly appreciated. Thank you
