Hi,
I am new to the forum and a little new to working on these skis. I have browsed through but have not found a solution that worked yet.
I have a '96 Seadoo XP. Second ski that I do not use very often except other ski is in shop so thought I would try and get this one going. Tried to start and would only get the solonoid clicking with no action at the starter. At first, thought it was battery and battery happened to be old so bought brand new gel battery. Same thing. Removed and replaced starter with new starter. Motor turns fine with no plugs but once plugs are in it will turn slightly but then stop after maybe two-four revolutions. I then noticed the old starter had a nut and what appeared to be a broken piece of wire. Realizing this was where the ground wire should be I removed the ground from where it was attached (obvisouly by last owner) to top half of motor and reattached it to one of the bolts holding the new starter on. Still same thing. Not an oil or hydro-lock situation. When plugs are out not spitting much out holes except some gas.
Ok, more info. VTS in this ski smokes from the actual unit in rear. Disconnected VTS after looking at manual using 3 plugs under main compartment. Dont know if this has to do with anything but when VTS was hooked up (and smoking) still did not start.
Here are some other items I noticed:
Ground cable gets very hot when trying to start. Burn yourself kind of hot.
When attempting to jump posts on solenoid, started gets a tiny kick but posts arc bad.
When I hook the battery up, even with lanyard not connected I can hear a click and see a spark at the battery terminal as if there is something constantly draining on the battery.
When I try to start it and it turns once or twice and then stops, it will only making the clicking noise from the solenoid until I manually turn the drive shaft. Then it will do the same thing again until stuck.
If anybody has any insight, would be greatly appreciated. Getting kind of frustrating. Lastly ski was not winterized fully if that could cause anything. Was in enclosure and cylinders were fogged out and all water was drained and dryed from hull area but not much else.
Thanks,
Keith
Thanks,
Keith
