'96 Seadoo HX - Exhaust Copper Sealing Ring??
MaltDisney
Hello Everyone, I've done a bit of searching, but have not had any luck.
I have a 1996 Seadoo HX that I purchased a few years ago. It came with a factory pipe setup, but it's been a real pain to tune, so because I'm not racing it I'm reverting back to stock.
I've purchased 99% of the parts that I need, but one part is holding me back from assembling the stock exhaust, and that is the copper sealing ring, part #274000152. The part is NLA, so it's looking like my only option is to hope that a used one shows up on Ebay.
Mostly I'm just curious if anyone else has run into this problem and found an alternate solution. Anybody have any ideas? I see that other sealing rings are available online, like 274000511, but this is not for the 720 engine, is there a difference?
Any help is greatly appreciated!
You can try Westside Powersports. He might have a good one laying around.... Otherwise eBay is going to be the ticket. They are no longer available from the dealer.
OK thanks, I'll check with them. There are some other sealing rings that are available new/aftermarket including 274000511, 274000169, do these have different diameters and or thicknesses?
I believe the 511 part number is for 951 skis and the 169 part number is for 787 powered skis. I’m honestly not sure of the dimensions, so someone else will have to step in there, but I don’t think either of them will work in a 717 application.
Just to follow up, I called Nick @ Westside Powersports and he knew exactly which part I was referring to. Sent me an invoice and it is in the mail today. What an excellent resource - Much better than waiting on ebay & hoping that it is posted with the correct pn!
Thanks!
Thanks!
Good deal! Glad they got you taken care of!
