96 sea doo
cads
i have a 96 sea doo that i get no fire to the engine batteries are all good what can i check
It is rather simple with engines. They run off 3 things battery, ignition and fuel. If your batteries are good and the fuel is good the only problem can be the ignition. Pull your plugs out and crank over the motor and see if the plugs are getting spark. If they aren't getting spark you know it is in the ignition.
what about the kill switch
What do you mean you get "no fire" to the engine? Does the engine turn when you push the start button? Is fuel getting into the cylinders (wet plugs)?
