Hello everyone,
new here and also new owner of a 96 xp. Had some troubles on the lake this weekend with the ski. It will fire up but will die out if either too much throttle is given. I was able to get it to start quite a few times by giving it very light throttle for about 60 seconds then it would run and be fine till it was shut down again. Repeated the same process about a dozen times. Where should I start? The day before I took it out(first time I’ve taken it out) I replaced all of the grey fuel lines with some standard automotive 1/4 fuel line. Plugs are also new.
