Hi All,
I just bought this ski from a friend and he told me it has been sitting for two years without being used or started, but it ran great the last time he used it!
So I get it to the house and try to get it going....Needed a new starter, replaced plugs, siphoned old gas out and put fresh gas in it...Then I tried to start it....NOOOO such luck....Just cranks! It has good spark at the plugs, and if I sprits a tiny bit of starting fluid into the air box it fires right up and runs for a second and sounds real healthy! but wont stay running, that being said I'm guessing it might be a fuel problem! So here are a few questions:
What kind and where is the fuel pump located is it mechanical or electric?
Can I remove the fuel line to the carbs and crank it like you would with a car to see if there is fuel flow? Can the inline filter be replaced with a similar automotive inline filter or is it a special filter? I'm a pretty good mechanic but know very little about 2 stroke engines so any suggestions you all might have on how to troubleshoot this problem would be GREATLY appreciated!
Thanks in advance,
Mike
Thanks in advance,
Mike
