Hi all, I have a 96 hx with an ongoing problem that is progressively getting worse every summer.After the engine has warmed up, difficult starting, and when you do get it to idle,and give it throttle it stays at idle, this problem can last up to a minute,if you continously feather the throttle it will all of a sudden 'wake up' and the engine runs smoothly , has plenty of power and runs fine, but again as soon as you come back to idle its the same thing ,happens again, the problem gets worse when the fuel tank is around 3/4 or less and when engine is up to running temperature. When you first put it in the water, say first 15-20 minutes it runs perfect! Has factory pipe with the propper jets and pop off spring[ all the stuff factory pipe recomends] and a different prop I forget the pitch but its one that everyone suggested.also has a primer kit. Rebuilt the carbs twice no difference!, checked fuel cap, fuel selector, tank check valve, nothing!,clean main fuel filter but i do notice small black particles on occasions. mixture screws have been turned so many times I have probably worn them out!And there is probably some other things I have done but i can't think of them right now. after yesterday when it died 500 yards away from shore cause I killed the battery trying to start it, Im freakin pissy at this thing, bought it new in 96 and still think its the funniest ski ever made. But this ongoing problem that I cannot solve has got my shorts all wadded up, any help would be appreciated!
thank you!
thank you!
