ok i just got a 96 sea doo gtx 800cc 2 stroke and all that. The problem is the guy i got it from left the spark plugs out and water go in the motor causing it to rust. It was locked up so me and my dad put a pipe wrench on the drive shaft and some oil in the cylinder and finally got it free. It turns over good now but the oil in the crankcase still has water in it. How can i get all the oil out of the bottom of the motor with that nasty watery oil it fouls my plugs in a sec and its not good. Is there a drain plug on the bottom of the motor or what i just know i need to get it out. Also this seadoo has been sitting a year or so so i worry with the water in it and the rust in the motor will the rust mess up the crank shaft? i know the rust will wear off the cylinder walls but i worry about the crankshaft and the crankshaft bearings i wonder if they have rust on them and how bad will it hurt my motor?
thanks
thanks
