marke52896
Well another year and more problems. My 96 GTX was running fine when my son and friends took it out. Thought they got a rock in the impeller so they thought turning it over was a good idea to get the rock out. Of course when they finally turned it over they turned it the wrong way filling the engine with WATER!!! It also shorted out the started relay. So I cleared the water from the cylinders but the ski would not fire. There was water in rear electronics so I shorted across the starter relay and it fired up. Ran for a few minutes but while it was running I discovered there was a water leak comming from the gasket where the exhaust and block meet. Replaced the gaskets and leak moved to where the cylinder and block meet so I removed the exhaust, removed the cylinder and put it all back together. Still had to short across the relay to get the ski to fire but I still seem to have a water leak (yes I checked and replace the small tubes coming off the back of each cylinder, still a leak. So I decided to at least replace the relay but that did not help still and the short across to get the ski to run. It will not start by pressing the start button, replaced that, still nothing. Replaced the small electronic rectifier in the front electronics and still not luck starting with button. Checked at fuses and they are good. When I short across the starter relay she fires right up, runs strong for about 20 seconds and dies. Can restart and same result.
So, where else could a leak be coming from. Appears to be cylinder side, under the cylinders? Then what the heck the starting issue, why won't it start with the starter button. Finally why does it die after 20 seconds. Frustrated especially since it ran great when it first ran this year.
Thanks
Thanks
