there is no electric shut-off. there is a big knob you turn. i assume you found that. fuel lines grey? replace them. then clean the residue from dissolved fuel lines out of fuel filters in carbs. another prob i have seen on older models, the fuel pickup in bottom of tank is stuck shut. it is a one-way anti-siphon check ball. these are 2 most likely fuel problems to start with.
