96 GTX Sea Doo
1965impala
Hi! I am new to this site and am looking for a little help from anyone whom can give me some adivice. I have a 96 Sea Doo GTX that runs fine on the trailer, it even runs fine when you first put it into the water, but after you are on the water for about 5 to 10 minutes the sea doo seems to loose power almost as if it is starved for fuel. It has rebuilt carbs on it and I have checked the fuel tank to make sure nothing is clogged. Any ideas of what could be wrong with this thing??? Thanks for any help!
Have you cleaned your fuel selector switch? I had same problem when I bought mine a few years ago. Ran on trailer, but in water under a load it would die. My switch was all pluged up and wouldnt allow enough gas to run under a load.
To add to slvr built, does your seadoo still have the gray fuel lines? If it does they need to be changed out as they will cause clogged carbs also.
Karl
