chrisny454
The Problem:
96 GTX will not rev past 3000-4000 in the water after 5-10sec... However, it will rev all the way up as soon as I start it, then it will rev 5000-6000 next time I WOT, then finally it will not go past 3000-4000 at WOT regardless.
2 years ago I was able to beat the issue by just letting it warm up and gradually bringing up the RPMs. It would finally go past the limit and be usable for the rest of the day. Sad to say I can no longer do this and no matter what I do, I cannot get it the rev past 3000-4000.
The motor sounds like it is bogging or missing so my guess was that the computer's rev limiter thinks the machine is still out of the water. But I dont know what device/system tells the machine that it is in the water or not so I cant check for a faulty device.
I have NOT done the fuel lines nor cleaned the carbs/RAVE valves EVER so I know I need to do this, and that may be what I have to do first. BUT I was wondering about the Rev Limiter and how the ski knows whether or not it is in the water. If the machine thinks that it is out of the water still (Even though it is not) then I am 99% sure the rev limiter will kickin to prevent over revving out of the water.
Thanks for listening to my ramblings and offering any insight you may have.
ChrisNY454
ChrisNY454
