First off I checked all of the wiring and fuses.motor turns over just no spark.there are three black wires on the coil at the mount hole.off of those three wires comes another black wire that plugs into the side of the coil this is the negative.on the other side of the coil is a white wire which I thought should be the positive but it has no juice.I hooked the test light up and cranked it over and nothing.does any one know where this wire gets its signal or power.or if Im totaly wrong and you know where I need to look for a fix I would greatly appreciate it
